Ok 56- plate clunk??
ian_kell
Postby ian_kell » Fri Jun 01, 2007 1:25 pm
Got in my megane this morning and headed off to my mothers for lunch. Got to the speed bumps and heard a huge clunk passenger front side. Happened a few times and after driving around for a while got underneath and found all ok
Any ideas and is it safe to drive? I did read it may be a loose strut?
Phone my local garage and booked in tues for a road test. Is this the right way to go
Only worried as i have to got work tomorrow which is 35 miles on teh motorway. Any help appreciated
Iain
ICEMAN
Currently Drives:: Renault Megane II 1.5DCi + Lexus RX 300
Postby ICEMAN » Fri Jun 01, 2007 1:30 pm
hi iain
it is the best way, dont do anything yourself, as they will sate "your warranty is void"
im not that much of a mechanic, so not sure if it is road safe!! but if it only happes over bumps and your on the striaght shouldn't be a problem
let us know how it goes on the way to/from work...and what the garage say.
ian_kell
Well
Postby ian_kell » Fri Jun 01, 2007 1:33 pm
If i know my local dealer itll be nothing lol as all i have ever had is problems with them
I just worry the wheel is going to fall off or something !!
IainMW
Postby IainMW » Fri Jun 01, 2007 4:42 pm
Mine makes the same noise, has done from virtually new. It's been in to the garage several times now, still nothing can be pinpointed as to it's cause?
The shocker top bearings were replaced becuse the stearing used to go "Twang" when I was turning right. I have been reassured that nothing is loose or about to fall off.
Woody Woo
Postby Woody Woo » Fri Jun 01, 2007 8:40 pm
Mine has started making a feint thumping/clunking noise from the steering/suspension when I go over bumps or turn the steering to park. Haven't investigated it yet. Doesn't seem to be getting any worse so I may ignore it.
Renault Build A Better Car :D
ian_kell
This however
Postby ian_kell » Sat Jun 02, 2007 8:50 am
Isnt anything to do with steering i hope
Its loud as you go over bumps or potholes at slow speeds. At speed all you hear is a whizzing noise as if something is loose.
Read its a copmmon problem on Meggies on Parkers. Sure hope its a loose strut or something. Saying that its under warranty!
Iain
ian_kell
Well
Postby ian_kell » Sun Jun 03, 2007 12:09 pm
AM BACK HOME SAFE BUT STILL CAUSING PROBLEMS
CLUNKED ANYWHERE UPTO 40 mph THEN STOPS? pERHASP THE SPEED OF THE CAR AND SO I CANT HEAR IT
ian_kell
Bed spring
Postby ian_kell » Tue Jun 05, 2007 10:10 am
Theres the answer. Thats what my garage found
Made them all chuckle as they suspected much worse!!
iAIN
Users browsing this forum: Bing [Bot] and 50 guests
