AUTO WIPERS FAULT :(
Reno
Postby Reno » Sat May 12, 2007 9:20 pm
Hello
I got a R.Megane II 1.6 16v touring.
I have a problem with my front wiper.
It`s says "Auto wipers fault" in the message box, and there is light in "SERVICE".
When i put wiper in pos. 2 i just run normal, it´s not going i "sensor mode" there is no function either with 1 drop or 4 drop.
conclusion: my rainsensor / wiper not work ok
Any idea. (i have seen the question before in this forum,but no good idea :)
Yours faithfully, Reno from Denmark
Renault Megane II Touring 1.6 16V `04
DaveP
Postby DaveP » Mon May 14, 2007 12:49 pm
We had "auto wiper fault" come up once, however the wipers were still working fine in auto mode. Told the dealer and they changed the sensor under warranty and have never had the message again.
66TAF
Postby 66TAF » Tue May 29, 2007 7:21 pm
Does the fault message always show? as the wipers are very erratic when there is a slight drizzle and hardly ever set themselves to intermittent. Wondering if something is not right.
jkspoff
Postby jkspoff » Wed May 30, 2007 1:57 pm
Do the wipers have to be in intermittent setting for the auto wipers function to work, as I do not have a manual ?
Renault Laguna II 2.2Dci Privilege Tourer 2003, sat nav and Renault Scenic II, 2004, Dynamique 1.9 Dci, panoramic roof
Postby Stranger » Wed May 30, 2007 1:58 pm
jkspoff wrote:Do the wipers have to be in intermittent setting for the auto wipers function to work, as I do not have a manual ?
Yep, first notch down iirc
Privilege
Postby Privilege » Wed May 30, 2007 5:13 pm
You can also adjust the senstivity of them by turning the collar - higher number of drips makes it more sensitive.
Also remember on the pre phase II you have to reset them after you have switched off i.e. switch them off then back on again :)
Postby AlexB » Wed May 30, 2007 11:06 pm
https://www.meganeownersclub.co.uk/forum ... .php?t=410
Users browsing this forum: Google [Bot] and 34 guests
