Seat belt adjusters
Margaretdorothy2
Seat belt adjusters
Postby Margaretdorothy2 » Mon Apr 30, 2007 10:39 am
Anyone know where I can get seat belt adjusters, find that my belt even when lowered is still far too tight and uncomfortable after a long journey. Any suggestions :?:
Postby AlexB » Sun May 06, 2007 10:04 am
I doubt that they can be adjusted.
IainMW
Postby IainMW » Wed May 09, 2007 12:20 pm
Is this what you mean?
https://www.care4car.com/productdisplay/ ... _Klip.html
This won't fit the Megane (I don't think?) but you might be able to find something similar?
Postby AlexB » Wed May 09, 2007 4:24 pm
This is what UK MOT regulations say on the subject of MOT failures:
"... a retracting mechanism does not retract the webbing sufficiently to remove all the slack from the belt with the locking mechanism fastened and the seat unoccupied
Note 1: In doubtful cases, this should be checked with the seat base set in its rearmost position.
Note 2: The vehicle presenter should be advised of and given the opportunity to remove any temporarily fitted device likely to cause failure under this reason for rejection before notification of refusal is issued."
Then, I am not sure what the insurance company may say in case of an accident. In any case, don't fit this thing to the passenger belt due to possible legal issues...
Sorry, I recognise the problem, but don't know how to help.
Margaretdorothy2
Postby Margaretdorothy2 » Thu May 10, 2007 7:14 pm
Thanks to you all, managed to adjust belt, moved it up slightly, this solved the problem even more when I moved my seat back a little.
