Weird Noise On Startup
L33SA
Postby L33SA » Thu Apr 12, 2007 10:18 am
:shock:
My car has been making a weird grinding? noise when I press the start button, but it was not that often and the car started up fine so I just thought it was something stupid.
However, :( going to work all this week when the car is cold the noise is so loud and it wont start first go.
Hard to describe the noise - a bit like a loud drill or fan? Sounds like its comin from the drivers side.
Any ideas?? Am hoping its somethin cheap to fix :roll:
Car is 1.6 dynamique many thanks xx
Oilburner
Postby Oilburner » Thu Apr 12, 2007 10:28 am
At a guess, it sounds like the starter motor is on its way out. Especially if the noise always stops after the car has started.
Probably not that cheap, but not catastrophic either.
Pete
2006 Megane 2.0 Privilege (traded-in after two weeks!) & 2006 Grand Scenic 2.0 Dynamique (rejected due to paintwork problems)
L33SA
Postby L33SA » Thu Apr 12, 2007 10:45 am
Thats what I was thinkin it will be, but whenever I get someone to come and listen it never makes the noise :P
Im glad its somethin quite simple anyway..but how much are these motors?? I will not be goin to renault as this is somethin my dad will be able to do
Thanks oilburner xx
I never had any problems til I started reading these forums you know lol :roll:
Oilburner
Postby Oilburner » Thu Apr 12, 2007 11:04 am
Sorry no idea on cost. Try giving GSF a ring?
I know what you mean though, I think I cursed my car by coming here before I even bought it! :lol:
Pete
L33SA
Postby L33SA » Thu Apr 12, 2007 1:15 pm
Oilburner
Postby Oilburner » Thu Apr 12, 2007 4:12 pm
It would make me a bit nervous that they make a point about so called timewasters asking for refunds.
If the part isn't as described or doesn't work then they have to offer a refund and take the item back.
Still, if they insist the item is genuinely working, then it should be OK?
Pete
MrAsia
Postby MrAsia » Thu Apr 12, 2007 6:21 pm
Should be fine, says its been tested and serviced.
If it doesn't work just return it.
Use paypal, easier to dispute if something goes wrong IMO.
Remapped Mégane 1.6L
cindognito
Postby cindognito » Sat Apr 14, 2007 7:37 pm
Renault (Parks, Irvine, Scotland) just renewed my starter motor on my March 2003 1.6 Megane.
Cost including VAT was £320.
walibe
Postby walibe » Sat Apr 14, 2007 9:57 pm
Where the hell do Renault get these prices from? lol
L33SA
Postby L33SA » Sat Apr 14, 2007 10:25 pm
How did you know it was the starter motor cindognito? Did it start to make the weird noise I have described??
walibe
Postby walibe » Wed Jul 04, 2007 12:03 pm
My cars just started doing this, and straight after a service but its not all the time.... Is this definatly the start motor? (Its what I originally expected).
IainMW
Postby IainMW » Wed Jul 04, 2007 2:45 pm
L33SA's turned out to be the Dephaser Pulley :(
walibe
Postby walibe » Wed Jul 04, 2007 3:15 pm
Hope my RAC warranty covers that then...
walibe
Postby walibe » Thu Jul 05, 2007 7:14 am
Bit strange. When parked overnight at home on a sloped drive the car starts first time. Here at work also on a slope (both down and the left) I get the above symptons. This only started after the massive down poor, could this be anything to do with it? Should I let loose the WD40?
L33SA
Postby L33SA » Fri Jul 13, 2007 2:02 pm
Haha.. When I first started to have this problem, the grinding noise on startup would never happen when my meg was parked outside on our drive (its sloped!). But it would usually always do it when I was finishing work and on any flat surface. Im sure my OH used to think I was hearing things because it would never do it when he was there at home!! Its VERY weird to say the least. In the end though, it did the noise on start up no matter where it was, even after standing for just 30 mins :(
Hope this isnt the start of dephaser pulley for you walibe I really do!!
