Solar Trickle Charger
Is it possible to leave one of these connected to your cigarette lighter socket or does this cut out from the battery when the engine is off? If so, how could you connect a trickle charger to your car? How would you be able to have the solar panel on your dash but the wires running into the bonet to connect to the battery? Would that be possible?
John
Is it possible to leave one of these connected to your cigarette lighter socket or does this cut out from the battery when the engine is off? - Yes it cuts off
If so, how could you connect a trickle charger to your car? crocodile clips
How would you be able to have the solar panel on your dash but the wires running into the bonet to connect to the battery? Would that be possible? Yes, just fiddly.
Chris
Chris
