Gear Knob
Meggyman
Currently Drives:: 56 Megane CC 2.0 Privilege in grey.
Full leather etc
Gear Knob
Postby Meggyman » Thu Jun 15, 2006 4:02 pm
Why is the Megane gear Knob so easily marked.
Have a fiesta too and it stands up to the rigours of daily life much better than the Smegane all round.
Renault state a new Knob is approx £40 for a replacement, and you can't just buy the easily marked top piece. You have to buy the whole knob.
Other than that I am so damn careful to the point where I hardly touch any part of the interior for the fear of marking or damaging anything.
Megane 53 plate 1.6 VVT Dynamique.
Ray
Postby Ray » Thu Jun 15, 2006 4:31 pm
thought you'd be able to get one under warranty... i think a few here have already.
You could try a scrap yard. The FAQ on this site has the instructions how to remove the gear knob.
the big yin
Postby the big yin » Thu Jun 15, 2006 10:31 pm
Mines turned brown and was replaced under warranty and mines is 3 in Seotember
Meggy 1.6 VVT Dynamique
Illusion Metallic Green
hibsfan
Postby hibsfan » Wed Jul 05, 2006 2:52 pm
My (late) 05 plate has faded badly, to the point that I can't read the gear numbers on the top of the knob.
I'll be asking for a replacement next month, when it's due a trip to the dealers for it's first service.
I ain't paying for a replacement, I can tell you that much!
Ex Megane owner.
soterman
Postby soterman » Wed Jul 05, 2006 6:11 pm
Mine is slightly scratched and the numbers have slightly faded.
I am within the warranty period and I have enquired at 2 dealerships. The answer I got was the same (dealerships are 240km apart): 'Sir, you have sweaty hands and the top bit was not designed to withstand this kind of treatment'
Well I knew that beforehand! Both said that they will not replace the knob, as that would be 'normal wear and tear'. Phoned at Renault's centre office in Athens (just for the fun of it), and yes the answer was the same - normal wear and tear....
'05 1.6VVT Megane II[/color]
Basenji
Currently Drives:: Megane 2 hb
Postby Basenji » Thu Jul 13, 2006 7:29 am
Well, there might be a solution:
zdrówko
Meggie slightly customized http://pl.youtube.com/watch?v=aD_K0VbKYGs
Skype: basenjittt
Mondo
Postby Mondo » Sat Jul 15, 2006 11:14 pm
Mine is also badly scratched (this was done by the previous owner). I want to replace the knob too. The problem is: how do you remove the knob? Is there some secret trick...?
Scenic
Currently Drives:: Scenic 111 1.9dci 2010
Postby Scenic » Sun Jul 16, 2006 10:24 am
Mondo
Postby Mondo » Sun Jul 16, 2006 10:35 am
Thanks. You pull it straight up then, right? As far as I know, most other knobs are threaded...
Megane II
Currently Drives:: Renault Megane II 1.6 Dynamique.
K&N Filter
Bilstein B6 Suspension
Megane RS springs
Toyo R1R
Pioneer 8200BT
Postby Megane II » Fri Jul 21, 2006 6:14 am
soterman wrote:Mine is slightly scratched and the numbers have slightly faded.
They have changed mine under warranty.
Michael Schumacher.
7 times F-1 World Champion.
500937680
Postby 500937680 » Wed Jan 17, 2007 12:03 am
well.. i think i'm not being so lucky as others. I'm trying to pull my knob off for 3 straight days..and nothing. :cry:
Bobbobadobob
Postby Bobbobadobob » Wed Jan 17, 2007 9:20 am
500937680 wrote:well.. i think i'm not being so lucky as others. I'm trying to pull my knob off for 3 straight days..and nothing. :cry:
Souldn't you see a doctor about that???
____________________________
06 Dynamique 1.6 VVTi, Mercury.
500937680
Postby 500937680 » Wed Jan 17, 2007 9:24 am
I'm going to the Witch 8)
referee
gear knob
Postby referee » Wed Jan 17, 2007 12:42 pm
I have had 2 replacement gear knobs both under waranty. Renault are aware of this problem but are failing to address it. My dealer has been onto them for seven months now and still they dont want to find a solution..
Speed is only relevent if you pass some one
scoop
Postby scoop » Wed Apr 18, 2007 8:35 pm
Gettin mine replaced on Friday under warranty along with bottom ball joint which failed on first MOT. Pays you to go to a dealer for your first MOT test, I was suprised it was covered but there you go!
Kind Regards
Scoop
04 Megane Dynamique 1.6 VVT 16V / Cherished plate / In Black 5 door / Lexus lights, Mint!!
"Shut Ya mouth and give Ya Arse a chance"!
