Brake System Fault
AndyAitch
Currently Drives:: Megane II CC Dynamique 1.5DCi
Brake System Fault
Postby AndyAitch » Thu Apr 25, 2019 10:11 am
So. Yesterday I was sitting in the car with the engine off but my foot on the brake pedal and the pedal started to sink. It's done this before and, as soon as I've started the engine, all's been good. This time, I started the engine, pedal came back up to pressure, I drove about 100 yards and the pressure had gone, the pedal pushed all the way down and the STOP light came on with the BRAKE SYSTEM warning. I've topped the fluid up just in case but it's made no difference... I think I have a leak somewhere. Does anyone have any advice as to where it might be?
I'm beginning to really miss my MG ZT...
Sorry, forgot : 2007 Megane 2 CC 1.5DCi
Ta
scooper1000
Re: Brake System Fault
Postby scooper1000 » Thu Apr 25, 2019 4:06 pm
Might be a idea to start at the obvious fault points, After pedal goes soft look underneath car and check if any signs of fluid on the inner wheels and tyres also check if Master Cylinder leaking if no signs of a leak it more than likely a faulty Master Cylinder.
will be easier if wheels are removed to check rubber hoses and wheel cylinders...good luck with your problem
joe12
Currently Drives:: Megane estate 1.5dci 86
Postby joe12 » Fri Apr 26, 2019 9:01 am
That sounds like your Servo (Brake Booster) is leaking vacuum, test the operation of that first.
https://www.youtube.com/watch?v=M2AnK8Q90Lo
Cheers.
AndyAitch
Postby AndyAitch » Fri Apr 26, 2019 2:10 pm
Sorted, brake line split on drivers side front wheel. Getting it fixed over the weekend. Thanks all :-)
joe12
Postby joe12 » Sat Apr 27, 2019 8:04 am
Good to hear you found the problem.
Cheers.
Users browsing this forum: Google Adsense [Bot] and 26 guests
