Hi everyone.
Firstly I would like to apologize if this has already been asked on here but I cannot find anything but I'm also new to the forum.
I have a 2009 megane CC.
It's recently had a problem with the battery draining for no reason. I have also found the windows stay operational all the time. The steering locks and radio goes off, but the windows work 24/7.
I also have found that my button that operates all the windows at once has stopped working.
I thought it may be a relay or bad switch etc so replaced various parts but had no joy.
The strangest part is. If I disconnect the battery for 4± hours and reconnect Everything works perfectly for around 48hours. Then we are back to square one.
Any help or advice would be greatly appreciated as I'm pulling my hair out.
Regards
Daniel
Windows don't turn off and all windows button stopped working
Re: Windows don't turn off and all windows button stopped working
So I changed the BCM module behind the glovebox but that didn't solve anything so I have put the original back now.
I have now changed the fuse box under the bonnet and so far the windows all stop working when the ignition is switched off. Maybe just a lucky day but I try it again later.
The button on my centre console that should operate all the windows together worked for a few hours and now only 2 windows work jumping down 5 cm at at time. This is also the same when operating the roof.(all windows should open fully)
All the windows work fine on their individual buttons
It's so frustrating and I can't find any wiring diagrams for the the CC
Maybe someone has some ideas what to try next.
Try over at the Renault forums, it seems a bit more populated so you may get more help on your subject.
https://www.renaultforums.co.uk/forum.php
Cheers.
Cheers.
joe12 wrote:Try over at the Renault forums, it seems a bit more populated so you may get more help on your subject.
Cheers.
Thank you, Will do
Users browsing this forum: No registered users and 89 guests
