Renault Megane 2005, (Estate 1.9 DCI) - Injector Problem
mixdesign
Postby mixdesign » Mon Mar 11, 2019 10:08 pm
I have a Renault Megane 2005, (Estate 1.9 DCI), this morning it wouldn't start, on taking it to my local garage by roadside recovery a test stated that all four injectors were leaking (apparently 'flooding back'). The garage has offered to send them away to confirm if all four are bad and need full replacement.
Is this common and how likely is it that all four have failed?
Any advice appreciated . . .
Jay1232
Currently Drives:: Megane
Re: Renault Megane 2005, (Estate 1.9 DCI) - Injector Problem
Postby Jay1232 » Tue Mar 12, 2019 1:35 pm
1 why didnt they stick it on a diagnostic machine 1st
2 Are they trust worthy incase your injectors are sat on the side and they saying they will send them away and only 1 has gone im sure they could test em tbh
alanf
Postby alanf » Tue Mar 12, 2019 2:44 pm
Seems a bit suspect that all four are duff, a small air leak will let the fuel run back to the tank and make starting difficult, try new leak off pipes and check all other accessible joints, even the priming bulb as the non return valve in them can be faulty.
Alam
Users browsing this forum: No registered users and 57 guests
