Parasitic Draw
TheGimp
Currently Drives:: Renault Megane 2 Sport 1.4
Ford Focus MK2 1.8 TDCI
Parasitic Draw
Postby TheGimp » Thu Mar 07, 2019 7:53 pm
So I've recently bought a Megane 2 (2003 5 door hatchback, 1.4) and it has a draw on the battery. After a couple of days of sitting in the drive it won't start, for obvious reasons. Now I've checked the draw to be at roughly 110 - 130 mA. I've checked each circuit and I've narrowed it down to a fuse by the glove box. It is the 4th one up from the bottom, a 20a fuse. The circuit on that fuse controls the radio - offset display - heated door mirror control - alarm - instrument panel. I've checked the radio, offset display & then finally checked the instrument cluster. I unplugged it & the reading dropped to 60 mA. Once I plug it back in it jumps back up to 110 - 130 mA.
I know that a normal amp draw is somewhere between 50 - 80 mA. Is the instrument cluster faulty or is it meant to draw that much? I wouldn't think that just the immobilizer red LED blinking on and off would have such a draw.
Has anyone else experience anything like this or similar?
FYI, these readings were taken when all doors closed, interior lights off & car locked.
Any help or insight to this would be greatly appreciated :-)
steve-t
Re: Parasitic Draw
Postby steve-t » Fri Mar 08, 2019 6:21 pm
Glove box light, Dodgy switch had it on a Clio.
Try pulling the bulb out.
Steve
