2005 Renault Megane Estate - Door locks
Rick
Currently Drives:: Renault Megane EXP- SION VVT
Postby Rick » Mon Mar 19, 2018 4:49 pm
Initially all the door locks failed but I managed to manually open the passenger door to get in and now all doors do not lock. Card key battery replaced on both cards keys I have, so I'm pretty sure it's the doors...Any ideas? Interestingly once you drive away in the car the doors will auto lock, but as soon as you stop they obviously unlock and remain unlocked!
grandadbobby
Re: 2005 Renault Megane Estate - Door locks
Postby grandadbobby » Mon Mar 19, 2018 7:09 pm
haven't had this myself, but I think you need to look at the driver door lock inside the door card for a poor connection/damp.
See how to remove door card on you tube.
At least give it all a dose of WD40.
I believe the driver door works the others in turn.
Bob.
neilbrumie
Currently Drives:: megane oasis 1.5dci
Postby neilbrumie » Mon Mar 19, 2018 9:02 pm
If the doors lock and unlock with the button on the dash,i would say the key cards are at fault,my car had this problem with both cards,if you slightly bend the card while pressing the buttons mine would lock and unlock.
