Which fuse do I need to change - and where do I find it?
Babararacucudada
Currently Drives:: Megane dynamique
Postby Babararacucudada » Thu Nov 23, 2017 3:06 pm
O7 Megane the dashboard light is not lighting up nor are the lights or indicators or petrol gauge or speedometer.
Will I find the fuse (I hope it is only a fuse) in the glovebox or under the bonnet?
Rosey
Currently Drives:: Renault Megane 07 1.6
Re: Which fuse do I need to change - and where do I find it?
Postby Rosey » Thu Nov 23, 2017 3:18 pm
I have this problem aswell and am looking for.help too if anyone can help I'm a new driver and new here
grandadbobby
Postby grandadbobby » Thu Nov 23, 2017 8:32 pm
does anything work on the car or are all the electrics dead.
lf so check condition of the battery and the large fuses at the positive terminal plus the earth.
Bob.
Babararacucudada
Postby Babararacucudada » Thu Nov 23, 2017 10:21 pm
Over to Rosey for that one - I was asking to help out but she has signed up now so there's no point me getting further involved.
I think she said the fuses all seem to be fine. Is there a master fuse for the circuits controlling those things or something?
grandadbobby
Postby grandadbobby » Thu Nov 23, 2017 10:50 pm
The master fuses are at the positive terminal.
Some clarity needed now to be able to help.
Bob.
scooper1000
Postby scooper1000 » Fri Nov 24, 2017 12:57 am
Silly to point out but itcould be the rheostat switch on the right of steering wheel on the dash...there are 2 switched 1 to dim dash and 1 to change height of the front light beams...sometimes polishing the car the switch can be moved....
stuartac
Postby stuartac » Fri Nov 24, 2017 10:07 am
This is a long shot, but worth a try. Have you got the 'automatic headlamps' feature enabled - the one where the headlamps come on automatically when it begins to get dark. If you have, then try disabling it. I seem to remember that this feature can sometimes 'get itself into a muddle', and cause problems with the dashboard lights similar to those you describe.
MarkSin
Currently Drives:: 2005 Renault Megane II Estate
Postby MarkSin » Mon Dec 11, 2017 5:44 pm
Did you ever find an answer to this problem?
My dash suddenly went dark this evening. No lights on the dash, no gauges work not even the speedo. The indicators don't make a sound but they work.
I hope it's only a fuse as well, but no speedo?? that seems really strange :(
GREENCLAWS75
Currently Drives:: Megane II 1.9 dCi estate Megane II 1.5 dCi
Postby GREENCLAWS75 » Wed Dec 13, 2017 12:29 am
It was the plug on the back of the instrument binnacle for me that had worked loose. The crash pad above pulls up and back and the screws holding the clocks in are behind. Hope this helps.
Users browsing this forum: No registered users and 88 guests
