Megane GT220 clutch position sensor DTC
The section for all Megane III talk.
crazyazz
Postby crazyazz » Tue Jun 13, 2017 11:54 pm
Hi guys,
Replaced the battery in the GT220 , now the following code comes up. Other code cleared ok but the clutch position sensor error. Only appeared after the battery was changed. Any ideas?
candleman
Currently Drives:: Megane3 Sports Tourer 1.5dci 110 Expression+
Re: Megane GT220 clutch position sensor DTC
Postby candleman » Thu Jun 15, 2017 8:58 am
Do you have stop/start and do you use it? If its been disabled then you might not realise the switch on the clutch pedal is faulty or a wire has broken. That's where I would look first. Sometimes a high resistance in the circuit can also throw a fault, so disconnect the connectors to the switch and reconnect a few times to clean them up a bit and see what happens. Its worked for me on other DTC sensor faults related to switches.
Candleman
How many more times, it's not an estate it's a SPORTS TOURER
Azzuro Blue 1.5dci 110 Expression+ Sports Tourer
Return to “Megane III”
Users browsing this forum: Google Adsense [Bot] and 5 guests
