Camshaft sensor
Mtb
Currently Drives:: Megane mk2 convertibel
Camshaft sensor
Postby Mtb » Fri May 19, 2017 3:17 am
Hi everyone , I have a 05 megane cabriolet and I need to change the camshaft sensor...... Any one know where it is as I can't find it
Thanks in advance !
BrotherPlasterer
Currently Drives:: 2005 Renault Megane 2 1.6 VVT Dynamique
Re: Camshaft sensor
Postby BrotherPlasterer » Fri May 19, 2017 3:40 pm
Top right of engine looking from front.
Just to the side of the sparkplug on cylinder no 1 (French) furthest from auxiliary belt.
I think its a 10mm bolt and you are able to get it out with some manipulation of spanner.
Remove the coil first to make access easier.
Out of curiosity why do you need to change it?
Mtb
Re: Camshaft sensor
Postby Mtb » Fri May 19, 2017 6:15 pm
Hi thank you for the reply , I am replacing the sensor as it came up on a fault code , so I thought first as last buy a new one and have done with :)
BrotherPlasterer
Re: Camshaft sensor
Postby BrotherPlasterer » Sat May 20, 2017 2:19 pm
Fair enough, what was the code?
Any symptoms?
Mtb
Re: Camshaft sensor
Postby Mtb » Sat May 20, 2017 2:40 pm
Hi there 2 fault codes came up ,
P2002 & p0340
The soot filter is driving me nuts , the " regenerate the soot filter " is on and off more than I drive the car lol.
P0340 came up for the Camshaft sensor , so I purchased a new one
Melanie
BrotherPlasterer
Re: Camshaft sensor
Postby BrotherPlasterer » Sat May 20, 2017 3:23 pm
Ah a diesel.
Do you motorway much?
Maybe it needs a good burn out at constant high speed for a while.
With regard to the cam sensor, if you got one already then change it but don't throw the old one because its probably only dirty.
Let us know.
Mtb
Re: Camshaft sensor
Postby Mtb » Sat May 20, 2017 4:55 pm
Thank you ever so much for the advice , I don't do a lot of motorway driving , so I am thinking or having the engine and system Terra cleaned to see if that will help :)
Users browsing this forum: Google Adsense [Bot] and 16 guests
