Oil Plug problem
The section for all Megane I talk.
jdashburn
Currently Drives:: 2001 Renault Megane Cabriolet
Oil Plug problem
Postby jdashburn » Wed Jan 04, 2017 3:08 am
I have a 2001 convertible. I went to change the oil and discovered that the oil pan plug is not a normal hex bolt. It is a recessed 4-sided plug that is a bit smaller than a 3/8 inch drive. Anyone know of a tool to remove the plug? I have not been able to locate one.
If not, anyone have a good idea on how to fashion a makeshift tool?
I thought about grinding down a 1/2 inch to 3/8 inch adapter...
Thanks,
James
spiggot
Currently Drives:: meganne vvt 1.6 sports tourer, in silver (best colour), very reliable and good handling.
Re: Oil Plug problem
Postby spiggot » Tue May 09, 2017 6:53 am
Hi, you can buy an adapter for your sump plug from renault at around £26+vat, bit pricey i know but saves the skin on your knuckles!!!
jamesjupp
Currently Drives:: renault megane 1 coupe - 2000 - 1.6 16v
Postby jamesjupp » Sat Nov 14, 2020 7:22 am
its an 8mm square plug. you can get the tool from any motor factors for about a fiver, or about a quid of Aliexpress.
dont go to renault for tools, they aint special.
Return to “Megane I”
