rear window temic repair
ChrisM
Postby ChrisM » Mon Sep 12, 2016 7:37 pm
AVOID!
ebayer qer_ltd.
He pertains to repair your temic unit for £29:99. Excellent how ever when returned I plugged in to the old motor and tried works perfect works off door buttons and all windows button.
So rip out old motor plus reg and plug the origonal motor on origonal reg chuck it all together bobs ur uncle. ........
Roof back on so all windows down mmmmmm 3 down 1 stays up once roof on all windows up and oh dear 3 up and 1 DOWN! Works opposite on door switch.
Cut a long story short the motor runs backwards now. Tried restringing but issue is the down cable is now too short so it pops out of the runner and jams.
Needless to say not a single word from the ebayer, gone to ground as they say.
The fix. Use a driver side spindle instead of the passenger one wrap cables as usual but motor has to now be modified by drilling out the mounting holes so they are large enough to take 2 10mm bolts, you then have to turn the motor around so the back of the motor is now the front. What this actually does it get the open cable back to the inside run therfore shortening it to where it should be, what I did find out when you restring your rear window regulator use the original springs they are about 5mm shorter that the kit onesand it counts as the white plastic guide on the down cable pops out when the window is up put the original spring on and it stays in the motor by about 3mm.
Excellent. .....
So from experience steer clear of qer_ltd for temic repairs should have been simple but turned into a 5 day fettling marathon but I think I have won this battle as it all works well for now I am sure meggie is already planning the re match though.
:D
