Both Front Door Speakers Dead
SteveMegane
Postby SteveMegane » Thu Sep 08, 2016 9:48 am
I have a strange fault with the Megane - Both front door speakers are not working? The dash tweeters work fine on both sides, just the ones in the door cards.
What is the wiring on these speakers - do they have a separate AMP?
Wickydude
Currently Drives:: Megane III estate 1.5dci 110 Limiited 2016
Re: Both Front Door Speakers Dead
Postby Wickydude » Thu Sep 08, 2016 8:05 pm
No separate amp.
In mine the speakers failed due to probably corroded contacts in the plugs on the back of the speakers. Took m off, sprayed the plugs with contact cleaner spray, put it back together and it worked again.
Had the same with the window motor twice, and the boot switch. All worked again after cleaning of the plugs and pins.
SteveMegane
Postby SteveMegane » Sat Sep 10, 2016 7:16 pm
This is the same fault. Thanks for the tips
Users browsing this forum: Google [Bot] and 81 guests
