I have a 56 megane cc 1.9dci and get fault code P0380 on my elm 327 intermittent problem seems to come up when engine warm. Also car shakes when problem arises
Any thoughts please
fault code P0380
Re: fault code P0380
Do you get any other messages on the display like "Check Injection'?
You might also want to check the environmental non-return valve on the top of the engine (located from the hose out of the oil filler point up to the top of the engine) if this becomes gunked up as blocks it can cause issues.
Other possible one to look at could be sticky EGR valve - how often has the oil been replaced over the life of the car?
The possible cause could be below - Glow Plug issue -->
P0380 - OBD-II Trouble Code
OBD II Fault Code
OBD II P0380
Fault Code Definition
Glow Plug/Heater Circuit "A" Malfunction
What does this mean?
The purpose of the Glow Plugs on a diesel engine is to heat up the combustion chambers to enable a quicker cold start. If the engine is already hot, the Glow Plugs aren't needed and will not 'light off'.
Code P0380 sets when the Power Train Control Module or PCM see less than 4 volts output to the Glow Plugs when the Glow Plugs should be energized or above 4 volts to the Glow Plugs when the Glow Plugs should NOT be energized.
Symptoms
Check Engine Light will illuminate
Failure of Emissions Inspections due to MIL malfunction
Vehicle may be hard to start
In rare cases, there are no adverse conditions noticed by the driver
Common Problems That Trigger the P0380 Code
Malfunction of the Glow Plug Relay
Malfunction of the GLow Plug Control Unit
Defective Glow Plugs
Defective wiring/connections in the Glow Plug wiring harness
Common Misdiagnoses
Glow plugs are replaced when the root cause is a defective Glow Plug Control Unit
Glow plugs are replaced when the root cause is a defective Glow Plug Relay
Glow plugs are replaced when the root cause is a defective wiring harness
P0380 Diagnostic Theory for Shops and Technicians
When inspecting for the cause of a Glow Pug circuit malfunction, I start by looking at the freeze frame data to get a picture of when the malfunction occurred. Then I use a data streaming scan tool and and zero in on the output voltage to the Glow Plugs. I'm looking for over 4 volts going to out to the Glow Plugs when I activate the Glow Plug warm up system. If there isn't, I locate the Glow Plug relay and test its function and its wiring harness. On systems where the Glow Plug relay isn't accessible, you have to test the Glow Plug Control Unit itself. Make sure the power and ground circuits going into and out of the Control unit have acceptable voltage drops. I look for .1-.2 volts (or less) on the ground side and .3-.5 volts (or less) on the positive side. I also check the Glow Plug harness for continuity by using a test light tethered to B+. I need to see bright illumination when I touch each of the Glow Plug harness connectors. This shows that the Glow Plugs and their wiring have solid continuity.
Good luck - let us know how you get on as its always nice to have feedback to help others in the future.
Kind regards,
Will
OBD II Fault Code
OBD II P0380
Symptoms
Common Misdiagnoses
Kind regards,
Will
2005 Scenic 1.9Dci 120 Exception
