225 engine swap into a 1.6
Im looking into putting a 225 engine in my 1.6 estate all i need to know is if the engine will phisicaly fit and are the drive shaft the same legnth ?
Re: 225 engine swap into a 1.6
Yes the engine will fit, however the drive shafts might be different, but I'd expect you'd be fitting the bigger brakes aswell to slow it down properly so it should be quite straightforward engine, gearbox, drive shafts, and brakes from the 225 and its done, aswell as parts from the wiring loom
