Megane mats
- Currently Drives:: Megane Dynamique Tom Tom VVT
Megane mats
I am new to this forum and hope that someone is able to help me. I have a Megane Expression. The driver's mat is fastened to the floor by means of two plastic caps fitting over two studs which are fixed at the factory. After a recent valetting the plastic cap for one of the studs has broken and I need a replacement. I am told by Renault Dealers that the only way is to purchase new mats! This seems to be a most extravagant and expensive way round the problem and I wonder if anyone can help me overcome this problem. Many thanks in anticipation. DennisL8on
- Stranger
- Currently Drives:: BMW X1
Re: Megane mats
If you mean the bit that sticks through from under the carpet then get one from a scrappers, lift your carpet, pull the broken one out and insert the new one.
If you do indeed need new mats have a look at this place. I've used them on a number of occassions, come to think of it they're that good that I wouldn't be at all surprised if they were able to help if you struggled to get the fitting from a scrappers,
Re: Megane mats
Very many thanks Stranger for your prompt reply. It is the plastic cap (?) which fits over the metal stud which protrudes from the floor of the car which I need. I'll have to keep trying for a solution - Velcro springs to mind though not an ideal solution! DennisL8on
