hey folks,
Got a 55 1.5 diesel megane estate and needing some help..
Fault code readers bringing up the following:
P0340 - camshaft position sensor A circuit bank 1 or single sensor
and
P0670 - glow plug control module control circuit open..
I have noticed on higher revs I get an injector fault warning on the dash and thought I may have an injector out, now Im not so sure
Can anyone solve or shed any light on this and a possible solution?
other thing is Im using clutch/brake fluid.. occasionally the clutch pedal will go drown and not come up as easy without some persuasion, gears can be hard to select if its got a little too low.. brakes dont seem to be affected at all so Im thinking its possibly the clutch slave cylinder as I cant find any leaks from the master..
Any help appreciated as I dont have a renault dealer near me..
Alan
code problems P0670 and P0340
