passanger side rear light cluster
booktrunk
Currently Drives:: Megane CC '55 Plate
Postby booktrunk » Tue Jan 05, 2016 10:35 am
Hi.
i've somehow managed to break the glass on my passanger side rear light cluster.
It's a '55 plate 1.6 (dec 2005) (passed 100,000 on it's 10th birthday month)
on the dreaded ebay there seem to be some that say 02-08 but some others say 06-10 as if they are two different sent of light clusters. Basically what years can i buy that will fit as a direct replacement. :)
Thanks in advance for your help.
morganjake1544
Re: passanger side rear light cluster
Postby morganjake1544 » Tue Jan 05, 2016 6:25 pm
A '55' plate (Dec 2005) is a Megane II, phase I. As such the light cluster should look like this:-
http://www.ebay.co.uk/itm/RENAULT-MEGANE-II-PASSENGER-SIDE-N-S-REAR-TAIL-LIGHT-2002-06-/321939075589?fits=Model%3AMegane&hash=item4af5107205:g:H0IAAOSwCQNWdcfe
with the lenses oriented vertically (almost).
The phase II was introduced in Feb 2006 and had lights like these:-
http://www.ebay.co.uk/itm/Valeo-Rear-Light-Lamp-Cluster-Right-O-S-Driver-Side-Renault-Megane-MK2-2002-2008-/331291975915?hash=item4d228a60eb:g:qS0AAOSwbqpT7zZ5
with the lenses oriented horizontal.
hope that helps. (I'm assuming you have either a 3 or 5 door.)
ChrisM
Postby ChrisM » Thu Jan 07, 2016 1:36 pm
If you have a hatch/saloon or estate car you are on the wrong section. The is for the cc in other words convertible. You could end up with the wrong information. Although reasonably at a base level the same there are some very different parts in some cases rear lamps being one of them cc rear lamps are completely different to hatch lamps even the rear bumper although looks the same is not interchangeable between hatch n cc. Some things we can help with but just let us know it's not a cc.
:D
