help me out windows and rear wipers
Oli3108
Currently Drives:: Megane privilege
Postby Oli3108 » Mon Oct 19, 2015 7:35 am
So I've just bought a megane privilege all seems fine but the passenger side windows front and back don't work and the rear wipers don't work nor can I get the water spraying to wash the back
I have checked the fuse box all seems ok
tanto12
Currently Drives:: 2005 megane sport tourer
Re: help me out windows and rear wipers
Postby tanto12 » Mon Oct 19, 2015 12:42 pm
the windows are probably suffering from the temic module fault search on this forum for more info on this the rear window washer is another common fault due to the washer motor failing when mine went every time I tried to wash the rear the front would go you can get a new motor from EBay for less than 10 pounds but check the hoses and nozzle before you change motor in case it is just a blockage
if at first you don't succeed get a bigger hammer
Oli3108
Postby Oli3108 » Thu Oct 22, 2015 5:22 am
A blockage wouldn't stop the motor working tho right.
How hard is it to remove the old 1
cliopapa172
Currently Drives:: megane privilege
Postby cliopapa172 » Mon Oct 26, 2015 11:30 am
Hi Try putting in a search on eBay for 'temic window repairs'. The guy has repaired two of ours now and he does a really good service! £30 each repair including P&P, but you can't buy these new and it's a safer risk than buying a second hand unit! Don't buy the cheap, easy fix units either as it means you can't have one touch or anti pinch control again! You will have the pig of a job of removing the door trims and all that goes with them, but it's the only way....unless you either sell it on or live with un opening windows!
Users browsing this forum: No registered users and 64 guests
