Rear screen demister not working - fix!
NeilS
Currently Drives:: Megane cc 1.9dCi Privelage auto
Postby NeilS » Mon Sep 14, 2015 10:55 am
Hi.
The rear screen demister stopped working the other day, so after checking the fuse (OK) I opened the roof to a half-way position and looked at the connections to the element, to find that even though the wire was fitted to the spade connector - the copper tag itself had become dislodged from the pad on the element.
The next thing to do was to remove the cover, which was a bit fiddly but not too difficult. Having good access to the area, I removed tarnish from the tag and the pad on the element with a small file to expose the copper. I used a gas soldering iron to tin the tag and the pad and then using a pliers to hold it, I soldered the tag back on to the pad. I closed the roof and started the engine to test the demister . . . and it worked. I then opened the roof half-way again to re-fit the cover.
I hope this post helps anyone who has a cc with similar issues. :!: One word of warning though - if you have the roof partially opened/closed, I think after around five minutes, the car beeps furiously, a message appears on the display and the roof opens/closes/continues on its way automatically. :shock: So you need to bear this in mind if you're doing any work that involves having your fingers or tools etc between the levers and support struts of the mechanism.
Here's a pic showing the re-soldered copper tag:
Note: the black stuff on the female spade connector isn't evidence of heat or burning (as I initially thought), it's some sort of insulation compound.
(Insert something creative/witty/imaginative here _ _ _ _ _ _ _ _ _ _ )
