cambelt 1.9 DCI 2005
kevlynnbailey
Currently Drives:: 2005 Megane convertible 1.9 diesel 6 speed
Postby kevlynnbailey » Thu Aug 20, 2015 3:06 pm
I have just bought it with 82k miles but its not clear from the receipts I have if the belt has ever been changed.
I have looked on eBay and one seller gave a warning to make sure the right one is purchased as there are two possible. Which is the right kit, also going to replace the water pump. I have found the locking pins on eBay. My motor factor is getting prices.
I assume this can be a diy job as I have been quoted £300
cba
Currently Drives:: Megane MK2 2004 + Several Motorbikes
Re: cambelt 1.9 DCI 2005
Postby cba » Fri Aug 21, 2015 12:02 pm
kevlynnbailey wrote:I have just bought it with 82k miles but its not clear from the receipts I have if the belt has ever been changed.
If you know what you're doing with a spanner, you should be ok.
MilosB
Currently Drives:: R. Megane 2 1.9dci sport package
Postby MilosB » Sat Aug 29, 2015 7:14 am
not quite a diy as there are no markings on the cams and you have to lock the flywheel inside the engine and time it etc. not simple at all on the 1.9 dci, and the method of symply locking all the cams to the current position is not really a god job
kevlynnbailey
Postby kevlynnbailey » Tue Sep 01, 2015 11:19 am
decided to let my local garage do the job. they did an excellent job.
cba
Postby cba » Sun Sep 06, 2015 5:57 pm
kevlynnbailey wrote:decided to let my local garage do the job. they did an excellent job.
how much did you end up paying?
s4k1b
Currently Drives:: lots of cars
Postby s4k1b » Mon Sep 07, 2015 4:56 pm
i would have thought it to cost around £125 - £200.
I know a local garage that does VW/Audi ones for around the lower end of that.
kevlynnbailey
Postby kevlynnbailey » Wed Sep 09, 2015 9:12 am
300 in the end. water pump, cambelt and tensioner with labour and vat.
