Hi, can you retro fit a auto dimming rear view mirror? The grey connector is there, so would I be able to fit a mirror and plug it in or would it need to be activated somehow?
thanks
Retro fit auto dimming mirror
- Currently Drives:: Megane II 1.5 dci 86 3 door
Re: Retro fit auto dimming mirror
If the Megane is like my old pug it just requires a power source so if you have the wiring it should work plug and play. The only issue I forsee is whether the bracket is strong enough for the larger, heavier mirror.
If the lead and plug are there you can just change the mirror,its a straight swap
- Currently Drives:: Megane CC 1.9 DCi Dynamique
Thanks for the replies, will get it fitted this week
- Currently Drives:: 2006 Megan CC Dynamique
Did you manage to do this?
My rear view mirror is cracked and I want to replace it. I figure I may as well fit an auto dimming one if they're compatible.
Just wondering how to get the existing mirror off so I can see if the wires are there.
Does anyone know how this is done?
Managed it no problem, remove the casing and the existing mirror slides off with a few gentle taps. Plug in replacement mirror and reverse the fitting
