megane windows
united369
Currently Drives:: Megane cc 1.6vvt
megane windows
Postby united369 » Tue May 05, 2015 12:22 pm
Does anyone know if its possible to adjust the windows, as the one on the drives door has a gap in some place 2-3mm, which today has let in alot of water.
the gap is on the side of the window whn you wind doedown an inch and then up again it fits under the roof as it should. Can anyone suggest what needs doing. Also i think i need some door seals as the 1s on it have gone deformwd and letting water in any1 know where i get them from?
Gumby6371
Currently Drives:: Megane II 1.5 dci 86 3 door
Re: megane windows
Postby Gumby6371 » Tue May 05, 2015 1:21 pm
I haven't personally stripped down the door on a Megane but it sounds to me like the glass has slipped out of position on its runners rather than a bad seal.
Unless the window seal is very badly deformed then I'd check the glass itself.
freelanderuk
Re: megane windows
Postby freelanderuk » Tue May 05, 2015 4:30 pm
There are a few post about adjustment of the windows on the forum have a search :D
The adjusting screws are under rubber grommets / door seal on the underneath of the doors , the rear are adjusted by removing the rear side panels :D
Drive it like you stole it
My flickr
