I have 2003 Megane II 1.9 DCI with about 177,000 miles on it.
Here is what happens. As I am driving, the car all of a sudden looses power and slows down, as if there is no fuel getting to the engine. If I push the accelerator down to the floor, nothing happens. If I lift my foot off the accelerator and then press down again like normal, the car continues to work like normal.
This has always happened with the car, about 4 years, but it was intermittent and the mechanic really couldn't figure out what was wrong. I replaced the EGR valve, but it did nothing. I considered the problem a quirk.
The past 4 days, the problem has started to get worse, especially in low gear. I start driving and loss of power, I lift my foot and press down and we are back in business, but sometimes it happens like 5 times in a row. Other times it doesn't happen at all.
The car starts with no problems and idles with no problems. I have no Injector/injection warning lights... It is only under acceleration when this happens.
Now, based on my reading I am thinking it is the HP pump (hope not) or a hole in the fuel line letting air in. To me, it makes sense the air in the line, cause it's as if fuel is running through the injectors and all of a sudden there is a bubble, so no fuel, then fuel runs through it again... there may have always been a small hole, but now it's bigger???
I understand that the fuel line is a clear tube.. although I have no idea where it is. Does someone have a picture? Please note my car is a left hand driver.
Any advice or thoughts or pointing me to a previous thread I missed would be much appreciated!
