Radio and Trip meter NOT storing
bikemad
Currently Drives:: megane coupe
Postby bikemad » Mon Feb 02, 2015 2:12 pm
HI the 03 Megane will not store radio code or any info i.e trip , mpg , range any ideas would be great thanks
Re: Radio and Trip meter NOT storing
Postby AlexB » Mon Feb 02, 2015 6:50 pm
Your mileage meter might be also incrementing every time you stop the engine... Similar faults were reported before - a fuse is blown somewhere or a wire disconnected. It is the same circuit that stays live and keeps the radio code intact when ignition is off. Never had this problem, so I can't tell you which exactly fuse to check. They are all listed in the workshop manual in the sticky thread with manuals, above this one.
bikemad
Postby bikemad » Tue Feb 03, 2015 4:33 pm
many thanks for your reply will have a look thanks again :-)
megowner2k
Currently Drives:: 2006 Megane 1.9 dci
Postby megowner2k » Tue Feb 03, 2015 9:20 pm
I've had sort of a similar issue with the fuel gauge, it was showing different everytime I started the car, also the range was scrambled. My problem sorted itself out when I replaced the battery which was 6 years old and was well overdue.
daleksean
Currently Drives:: 2005 Renault Megane ii Oasis 1.5 dci in Ottoman Blue
2011 Honda Civic (FN2) Type R GT
Postby daleksean » Tue Feb 03, 2015 9:21 pm
I had this exact problem. The problem was caused by a corroded fuse in the passenger compartment fuse box. The fuse your looking for is a Blue 15A and it is the one that shows a little picture of a radio. That had corroded in my one and it gave the exact symptoms you described. In your case your fuse could have blown. So hopefully that should help.
