Check Injection light problem finally solved for everyone.
- Currently Drives:: Megane 1.5 dci
Had the check injector light on now for around a year. Had my mechanic check the engine top to bottom. He'd change this and he'd change that. He came to the conclusion that it was the BOOST PRESSURE SOLENOID. After all the trying to find what it was it turned to be just that. I got a new one from renault parts for £60 including Vat and fitted it myself in less than two minutes. Turned the engine on and the light instantly wasn't there and my turbo was working perfectly.
Re: Check Injection light problem finally solved for everyon
thanks for the info
- Currently Drives:: Renault Megane 1.9DCi Sports Tourer (56 plate)
Thanks for this and glad you got it sorted
Do you know the error codes were on the vehicle?
What were the symptoms of your Vehicle? Was the turbo operating whilst the engine warning light was on?
