Anyone with can clip code reader
marshey
Postby marshey » Fri Aug 08, 2014 3:48 pm
Is there someone local to me that can read my car im in Chigwell, Essex. Ive tried a cheap code reader but it cant find anything.
Having hot start problems so i changed the common things like crankshaft sensor, coolant temp sensor and fuel filter but none have fixed it and cant keep wasting money changing parts i dont need.
fredcamp2
Re: Anyone with can clip code reader
Postby fredcamp2 » Sat Aug 09, 2014 11:47 am
3 of the very most likely areas for warm hard starting. A faulty starter will show a good rpm when cold & when warm draws to many amps depriving injectors. To check this out check amps draw on starter cold & warm. No 2 if your fuel pressure is borderline when diesel is cold it's heavy when warm thins out losing pressure. ckp sensors have a habit of going open circuit when warm. With out clutching at straws here my money would be on a faulty starter motor Hth Regards fredcamp2
