Megane cabriolet window problems
tonystime
Postby tonystime » Wed Aug 06, 2014 5:45 pm
Hi All
I have a problem with the rear windows on my car. The rear switches on the drivers door do not operate them and also the rear passenger switches will not operate them. However when lowering the roof, the rear windows go down and if you operate the centre consol window switch, they will go up again. They just will not work on the normal switches.
Can any help?
Tony
Meganeccdarren
Currently Drives:: Megane cc
Re: Megane cabriolet window problems
Postby Meganeccdarren » Wed Aug 06, 2014 6:07 pm
Check the fuse, it operates both windows on the rear via the door switches
Darren
tonystime
Postby tonystime » Wed Aug 06, 2014 7:35 pm
Hi
I've checked the window fuses ( 3) at the side of the glovebox and they are ok!
Tony
lovehercab
Currently Drives:: Megane cabriolet II
Postby lovehercab » Fri Aug 22, 2014 9:08 pm
Hi. I have the same problem with my cabriolet. the rights side of passenger window is not working properly. Its stock and cant open.I hope somebody can help need som tips and adviser! :life
iacapa
Currently Drives:: Renault Megane Convertable.
Postby iacapa » Sun Aug 24, 2014 5:04 pm
My two back windows will not open. I just purchased it last week. They were working then! Anyone know the problem as I bought it from a dealer 80 miles from home. It's a 2007 megane convertable.
Answer: Brought the car back to the dealer. It wasn't the fuse or the motors. He just said that it was a module which he ordered and fitted!
iacapa
Postby iacapa » Thu Oct 16, 2014 3:47 pm
It wasn't the motors or fuse. It was a module of some sorts or other which he fitted.
:ot I can't seem to find again how to post a question but does anyone know how to get a duplicate key cheaply? I have the plastic housing of another one but does anyone know if I can copy it, without paying a fortune? Thanks.
