uch board replacement
findlals
Currently Drives:: megane 1.5 dci
Postby findlals » Wed Jul 09, 2014 5:46 pm
Has anyone replaced a uch board on a megane mine got water in it and is now causing a few issues on my car
will any 1.5dci model uch board work and does it need reprogramming any info would be appreciated
Meganeccdarren
Currently Drives:: Megane cc
Re: uch board replacement
Postby Meganeccdarren » Wed Jul 09, 2014 7:32 pm
I'm sure it will need reprogramming
Not sure if any one will fit but I'm sure Alex Will know on here
Darren
TAS
Postby TAS » Wed Jul 09, 2014 10:31 pm
Are you sure it's the uch that's got water in it ?
The most common one is the UPC that's located NSF inner wing area in the engine bay.
These often get water damaged and cause all sorts of electrical issues. If this is the case you will be able to just plug it all in and start and drive the vehicle but it will need to have Clip plugged in to configure the alternator type.
If however it is the uch that's needed its a little more complicated. Keys will need to be programmed and there are a lot of other configurations that need to be checked/changed depending on vehicle spec.
Andy
findlals
Postby findlals » Wed Aug 13, 2014 6:07 pm
thanks for reply it is the UPC the one next near side wing
Will any model megane upc fit as all the con artist selling them on ebay say it will thanks
fredcamp2
Postby fredcamp2 » Wed Aug 13, 2014 7:24 pm
On your 1.5 dci if your model has the 5 pin relay which sits directly below the (uch) colour pink if so then you require the (upc)marked n2 this controls the high speed coolant blower. On models requiring the (upc) marked n3 the relay is intergrated into the uch you can just check the no's on your old 1 Recently I fitted a new (upc) from Renault total price £165 all in plug & play Hth Regards fredcamp2
findlals
Postby findlals » Thu Aug 14, 2014 5:48 pm
thanks for the info will get mine checked out :cool:
