offset
cally
Currently Drives:: renualt megane saloon mrk 11
offset
Postby cally » Tue May 27, 2014 6:37 pm
can someone please explain what the "offset" means referring to tyres.. i have read a few things on here but still none the wiser...
Meganeccdarren
Currently Drives:: Megane cc
Re: offset
Postby Meganeccdarren » Wed May 28, 2014 10:37 pm
Here you go
Offset
Lea esta página en español
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).*
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
*Backspacing, similar to offset, is the distance from the hub mounting surface to the inside lip of the wheel (measured in inches).
Darren
Users browsing this forum: Bing [Bot] and 23 guests
