Ta-Technix Coilovers
cally
Currently Drives:: renualt megane saloon mrk 11
Postby cally » Mon May 26, 2014 2:40 pm
Image TA-TECHNIX COILOVERS
Just to let everyone know.. DO NOT INSTALL THESE COILOVERS... I have just fitted them and they are shockingly bad and dangerous... They are advertised as lowering coilovers.. They make your car very unsafe to drive.. I fitted them and had to adjust them to full pre-load (full compression on these) There is no pre set pre-load on these.. You have to tighten up the spring so the car will hold the road and in turn sets your car back to the original ride height. They are very under-sprung and under dampened..
I understand not all ta-tec's have this setup... AVOID THESE LIKE THE PLAGUE...
