Megane MkII Brake problem
chaz143
Currently Drives:: Megane Mk2
Postby chaz143 » Sat Apr 19, 2014 6:10 pm
Hi all,
I have changed all brake pads (front & Rear) they were all really low. Everything went well 'but' now whilst driving it I notice a slight delay in braking reaction, seems slower to act.
Any ideas? I have now heard people say you should gentle scour the new pads before fitting them? Or maybe I didn't clean the discs of and got grease on one of them, although I'm 100% sure I was thorough.
Any advice or pointers would be greatly appreciated.
Thanks in advance
Chaz
freelanderuk
Re: Megane MkII Brake problem
Postby freelanderuk » Sun Apr 20, 2014 6:21 am
new pads need a few hundred miles to bed in , dont do any fast speeds and hard braking till you are sure the pads a well bedded in
Drive it like you stole it
My flickr
Postby AlexB » Sun Apr 20, 2014 3:40 pm
Do the discs look as new?
Are the pads of a premium brand or OEM?
Are you sure the discs are not contaminated?
Are the brake hoses like new?
Have you bled a litre of brake fluid to renew it?
Have you removed all traces of corrosion?
Did you torque everything to the specs, as in the factory manual (in the sticky thread)?
At least one "no", and you've got the answer. Otherwise, it's a matter of bedding in. In any case, the brakes in a Megane should feel like the car is able to stand on its front wheels if you press strongly enough.
chaz143
Postby chaz143 » Wed Apr 23, 2014 7:03 am
Thanks for the reply guys, it seems bedding in is all they needed as its improving each day and I'm 99% there back to normal braking. I am now encountering another problem :cry see link Meane engive revs. was meant to be megane but rushing for work :dead
Chaz
Users browsing this forum: Bing [Bot] and 10 guests
