Dash not working at all
chrisr
Postby chrisr » Sun Feb 09, 2014 11:41 am
Hi everyone,
Im new here and sadly my first post is one asking for help :|
I have an 53 plate Megane with a bit of a strange fault, The dash doesn't work at all, No spedo, No petrol gauge, No temp gauge and no ignition lights, I have tried all fuses and also tried changing the cluster but with no luck.
Is this a common thing or just something on mine?
Hope someone can help me to fix it then I can keep it and become a proper member of the community.
nickuk8
Currently Drives:: Megane II 1.5 DCi
Re: Dash not working at all
Postby nickuk8 » Tue Feb 11, 2014 11:21 am
hi i had a simular problem a little while back, have you tried the flat fuse on the positive terminal of the battery? mine wouldnt do anything so i just bodged up 2 pieces of wire and put a 30 amp fuse with some connectors on (renault wanted about £10 for the proper fuse)
it was a red fuse like this https://encrypted-tbn3.gstatic.com/images?q=tbn:ANd9GcSty7myc_4uvrnyb6w4qVJwi836Djj0gnXKvzwclbq4lpzsbvvcKw
worth a try i think,
Nick
Users browsing this forum: No registered users and 91 guests
