Evening Guys and Gals
Can anybody tell me whether the reverse light switch is the same on a 5-speed and 6-speed 1.5dci 2006 hatchback ?
I live in Italy and am struggling to make sure that I order the correct one.
I've found this:
https://www.dplus-autoricambi.it/it/rice ... 34-330248/
And it says its compatible with the following renault OEM part numbers
RENAULT: 77 00 422 630
RENAULT: 77 00 778 780
RENAULT: 77 00 802 640
Why are there 3 different part numbers ?
John
reverse light switch 6speed Megane 2
Re: reverse light switch 6speed Megane 2
6 speed box as a 3 pin plug
Thanks for the reply.
Just a curiosity, if the rear reverse lights don't work and i've checked the fuse and bulbs, is there anything else I should be checking apart from the switch ?
thanks
J
thanks
J
- ikhan
Maybe you can check the wiring to the switch?
Don't want to confuse you, but I think you need a 2-pin switch. I put my registration number in on the EuroCarParts website and they listed a few versions as well, but all were 2-pin and fitted the PK4 and TL4 transmissions. Interestingly, the same switch is used on the 2.0dCi as well (if I understood it correctly)
Renault Megane 1.5dCi (106)
Lowered 45mm (Spax)
Lowered 45mm (Spax)
