rear caliper to hub bolts
weldore
Currently Drives:: megane estate 1.9 dci
Postby weldore » Mon Sep 09, 2013 4:36 pm
its a megane estate 53 plate with the 270mm discs on the back.
its failed the mot on the rear discs so ive ordered new ones but upon removing the calipers from the hubs the bolts that go into the hubs were like chocolate.
where can I buy them from ?
sorry if its in the wrong place or been asked a million times :-)
cheers..dave.
triumph2.5man
Pug 307HDI90 1.6 (family car)
Re: rear caliper to hub bolts
Postby triumph2.5man » Mon Sep 09, 2013 9:43 pm
Hello Dave, bin there, dun that! Your Renault spares dept will be able to supply these but they are not kept in stock and will need to be ordered. Take smelling salts for when you learn the price! Having picked myself up off the floor I popped into the workshop and enquired if any spare bolts were available. A kind mechanic took me over to a box of odds and ends. I sorted through and found bolts of the same thread and length. No charge so some good things come out of Monsewer Renaults garages!
The original bolts have torx heads, E18 as far as I can recall. I don't mean to be insulting but did you use an E18 socket to try to remove them? An ordinary socket will just round the edges off. They are extremely tight and thread-locked too and rusty after almost 10 years. I expected to be able to supply the bolts from my own junk box but these ones have a very fine thread, not the normal metric size, something I have rarely seen before (and then on a PUG 205 rear suspension.)
Hope this helps. The best of luck....mate!
Mike
Postby AlexB » Wed Sep 11, 2013 3:33 pm
Isn't it m10x1 grade 12.9?
Careful with ebay. Bolts grade 8.8 and below take only half of the torque or worse. Note that grade 8.8 is often advertised as high tensile, which doesn't make it suitable for the application.
See, e.g. this (after checking the dimensions of your bolt):
https://www.ebay.co.uk/itm/M10-x-1-25P-F ... 4605afe845
weldore
Postby weldore » Wed Sep 11, 2013 6:21 pm
thanks guys..yeah I used the right sockets but I think they were too perished. I ended up dropping down to a 12 mm socket and a lot of swearing but managed it eventually :x
that's a good tip about going into the workshop :wink:
ive still to get some as the mot runs out on Saturday
thanks for the link alex and the stud info..ill let you know how I get on.
sorry for the late reply ,I forgot id asked about them :nut
cheers again , much appreciated..dave
Users browsing this forum: No registered users and 74 guests
