1.5 dci Clutch??
LydonJohn
Currently Drives:: Renault Megane 1.5 dci 106hp
1.5 dci Clutch??
Postby LydonJohn » Sat Aug 17, 2013 6:20 pm
I think i need a new clutch for my megane 1.5 dci (106hp) as the revs are running away without the power at 2000rpm :?
Some people selling say they're the same clutch as the 80hp model and some say they're different as the engine codes are different.
Some say the clutch diameter is the same on both models and others say the 80hp is 215mm and the 106hp model is 230mm. :?
Does anyone know where i can buy a correct clutch and flywheel ect?
Please help!
ikhan
Re: 1.5 dci Clutch??
Postby ikhan » Sat Aug 17, 2013 9:43 pm
The clutch is definitely different on the 106bhp model.
Cheapest place I found online was buypartby (if you're doing the job yourself, otherwise let the garage buy the parts). If you're just replacing the clutch, you have to match it witrh the flywheel that is currently fitted.
Renault Megane 1.5dCi (106)
Lowered 45mm (Spax)
LydonJohn
Postby LydonJohn » Thu Aug 22, 2013 5:10 pm
will it not be the standard dual mass? :/ thanks for reply by the way
ikhan
Postby ikhan » Fri Aug 23, 2013 8:48 am
I'm not 100% sure - I know the clutch itself is larger (230mm I think). When I was searching for mine on various sites (Euro Car Parts etc), they did have 'notes' that said certain clutches could only be fitted to DMF's with a certain part number IIRC. I think there's 2 different versions of the CSC too (one has 2 clips and the other 1 clip which makes a difference in terms of pressure - this I found on the LuK site I think)
Lowered 45mm (Spax)
