Injector fault light on 1st startup then goes off
Dboyleggy
Currently Drives:: Megane dci
Postby Dboyleggy » Mon May 06, 2013 5:30 pm
Hi everyone.
I searched for the answer on here already but no topics came up....
I have a 1.5dci megane which in 1st start up in the morning takes a few goes and writes up injector fault
It has been serviced over a month ago, has had the glow plugs changed as well but still does it.
It cannot be a injector as when it is running, drives absolutely perfect.
Any ideas what else it could be as I am now stumped?
Best regards
Re: Injector fault light on 1st startup then goes off
Postby AlexB » Tue May 07, 2013 11:11 am
This is a standard symptom of a glow plug or anything in its circuit. The glow plugs are only used when the engine is cold.
On the other hand, it can be something else. You need to read the fault code while the engine is still running. It will give you a hint. People often use ELM327 OBD interface from ebay, or many good garages do it for free.
Dboyleggy
Postby Dboyleggy » Thu May 09, 2013 7:35 pm
Thanks for the reply
I changed the glow plugs and to no improvement
It's weird cos once running she's driving perfect
Users browsing this forum: Google [Bot] and 39 guests
