Electronic Fault Megane 11 2004 1.9dci
Deejay2
Currently Drives:: Renault Megane 1.9 dci 2004 manual 5 door hatch
Postby Deejay2 » Thu May 02, 2013 1:37 pm
The service light and message "electronic fault" came on without warning. Car has been regularly serviced with 4200km to next service. Car is running fine but cruise control does not come on, although it was working fine before the message came on. I have reset the service light which changed the reading to next service but fault message and service light still come on. I've checked all fuses and all seems ok. Worried about wife continuing to use car in case it is serious and causes more damage.
Anyone had this problem before or what else can I check.
Deejay
Re: Electronic Fault Megane 11 2004 1.9dci
Postby AlexB » Thu May 02, 2013 5:49 pm
What was the regularity of servicing? If 2 years or 18000 miles, then the car is closing to the end of its life...
"Electronic Fault" is usually about a computer or network malfunctioning. Check the cover on the headlight access hatch on the left front wheel arch liner just in case. If the cover is missing or the liner damaged, then the block UPC on the left side under the bonnet may be damaged with water. I am assuming the battery is new, and you have checked its terminals and the fuses.
Deejay2
Postby Deejay2 » Mon May 06, 2013 5:47 pm
Services were regular and battery is good. I disconnected the battery and the fault message and service light went off when car was restarted. After driving one kilometre the message and light came on again
Postby AlexB » Tue May 07, 2013 11:13 am
Check the cover on the access hatch.
Users browsing this forum: No registered users and 162 guests
