Door open warning
IanLawson
Currently Drives:: Renault Megane 1.5 DCi 55 plate.
Door open warning
Postby IanLawson » Sun Feb 10, 2013 11:06 am
Hi everyone.
Today, the door open warning light on the dash display refuses to go out. All doors shut properly, boot and bonnet included. I can't lock the doors: double clunk when I press the key fob. :eek
Megane 1.5DCi, 55 plate. Just finished resolving a clutch problem and now this. :roll:
Any ideas, anyone? Can I hook up a laptop and diagnose this problem, or do I have to go to garage?
Now on the lookout for a Nissan Juke. (Another funky-ass fun car)
Ian
dimitrius
Currently Drives:: renault megane II 2005
Re: Door open warning
Postby dimitrius » Sun Feb 10, 2013 4:06 pm
Do the interior lights also remain on? if so then maybe check the door switch.
Postby Stranger » Sun Feb 10, 2013 5:16 pm
Check that theres not something stuck in one of the door latches, it takes next to nothing I experienced the same thing and one time it was a bit of webbing from my rucksack in the boot and another time it was a leaf in the passenger door latch.
Skidms9
Postby Skidms9 » Sun Feb 10, 2013 7:55 pm
Many likely causes for this but the most common faults are:
1. a faulty latch micro switch (check by disconnecting/reconnecting 1 door at a time and monitoring the indicator light).
2. broken wiring in the boot loom between the lid and body inside the rubber sleeve.
3. water ingress and corrosion of A or B pillar door connectors.
Anything more than that would need a little more diagnosis - which door is causing the fault, UCH interrogation etc.
