Dash lights and white dials
- Currently Drives:: megane 2 privilege
Does anyone know how to change the dash bulbs,and is there any white dial kits for a 2004 megane ? Thanks
Re: Dash lights and white dials
you can change the dials to ones from a model 06 onwards.. I think. not entirely sure if the dials fitment is the same but its the whole unit that will need changing. You can change the colour of your current dials but it's a lot of work. its a major overhaul with a soldering iron, if you chose to do this make sure you get the correct size led's. without a powerful magnifier its impossible. this mod has been done, not by me but its been done. only reason I know this is because I contemplated giving it a shot, until I realised how much work it entailed. I have an 08 megane, so my dials are the one's with the colours your after.
If you do go down the changing the unit road.. if the fitment is the same, the plugs in the back could be different I don't know, I would go to a scrapyard for the part, as I cant Imagine it being cheap to buy new.
matt
matt
- Currently Drives:: Renault Megane CC 1.6 VVT in Ottoman Blue
The plugs on the 06> are totally different to the ones before.
The LED'S can be changed i did mine and if your handy with a soldering iron then its not to bad a job but if your not i wouldn't touch it.
