how do i remove the painted internal door handles please
ignor the speaker pic
https://www.google.co.uk/imgres?um=1&hl= ... ,s:0,i:126
internal door handle removal
Re: internal door handle removal
Just had mine off today, at the bottom of the handle use a flat blade and insert in the join and twist it will pop off, to remove the back of the handle you have to remove the storage box in the door card if you have one ,there is a clip on the inside of the box which needs removing before the storage box can be removed , be careful with the lid it don't take much to detach from the box ,the screw in the door opener has to be removed and then you can pull the cloth trim away from the door card, its hinged at the top and clips on the lower part and sides
ok cheers
