megane cc back window
den1000
Currently Drives:: megane cc 1.9dci
Postby den1000 » Sat Sep 22, 2012 6:41 pm
Hi all any help would be good!
set off for work the other morning and put the window down to have a cig, as i set off water from the roof came in and wet the window switches and put the back window down, could not get it up with the drivers door switch or the switch in the back of the car the only one that now works is the switch in the center for all the windows. have taken off the switch and dryed it out, and i know the window is ok as it will go up and down with the center switch, it just will not with the door or back switch's all it dose is go down...
hope that you under stand what i mean. lol. and thanks for any help with this mater. oh have tryed the 10 second hold reset and that did not work..cheers
cityslicker01
Currently Drives:: Megane cc
Re: megane cc back window
Postby cityslicker01 » Thu Dec 13, 2012 11:55 am
Hi ,
Have just developed exact same problem bought a new switch to no avail , so was wondering did you find what the problem was ?
any help would be greatly apprecited .
Andy
den1000
Postby den1000 » Sat Feb 09, 2013 9:29 pm
hi there Andy, came across the fix by chance, tuck out the fuses for the windows and the stereo and put them back in now all is back to the way it was, all working. cheers and hope this helps
