Hi, I'm slowly getting to grips with the pig of a 225 Cup I bought a few weeks back!! However, there's something else I need to ask about, which is: The clutch pedal is 'loose' or 'sloppy' at the top of the pedal travel. The car appears to pull just fine though. I'm used to a really heavy clutch from my Clio 172, so is it me, could the clutch be on the way out, or is that normal for a 225?
Hope someone can advise?
Many thanks.
Clutch
Re: Clutch
The question you have to ask yourself, is does it slip. In a high gear?
Re: Clutch
If that's the acid test, then 'No' it definitely doesn't! So I guess it's just a case of getting used to it!
Many thanks for your reply.
- Currently Drives:: 225 R-sport
Re: Clutch
if i press my clutch slowly all the way to the end, (when it feels like the end) i can press a little harder and get a bit more, i think thats to disable stuff like speed limiter and traction control but not sure, my mates megane does the same thing
