Double Din in 2003 Megane?
carl555
Postby carl555 » Mon Sep 10, 2012 5:57 pm
Hi, got a 2003 Megane with the single din tuner list with slot underneath as shown below.
Is it possible to fit a double din headunit without too much hassle?
I can’t seem to find a facia adaptor for the 2003 model – are there any facias for a simple fit?
Also do you need any kind of ISO adaptor, regardless of Single or Double Din?
Cheers, Carl.
Our 2003 standard stereo...
corasdad
Re: Double Din in 2003 Megane?
Postby corasdad » Tue Oct 02, 2012 7:21 am
yeah they can be fitted you need a fasica from ebay £10 and when you take radio out there is a bar that has to be cut away 1min of a job very easy
https://www.ebay.co.uk/itm/RENAULT-MEGAN ... 4d033decfd
most double din radio will just plug in car wires already in place it is very easy
https://www.ebay.co.uk/itm/7-HD-Car-DVD- ... 2ebe3fa9d8
Postby wanda » Wed Nov 14, 2012 7:15 pm
Srd85
Currently Drives:: 2004 renault megane 1.6 dynamique
Postby Srd85 » Fri Dec 28, 2012 5:02 pm
Hey..
I've just got a pioneer double din for my megane and obvs need a facia surrond, problem is it's an 04 plate and all facias I can find are for 07 onwards, how much demifference is there?
Thanks Ste
corasdad
Postby corasdad » Fri Dec 28, 2012 8:06 pm
they will fit no prob
nik_rowlands3
Currently Drives:: Renault Megane Dynamique
Renault Clio Expression
Postby nik_rowlands3 » Thu Mar 21, 2013 10:43 pm
There you go dude will look like this
darny64
Currently Drives:: 2004 megane mk2 3dr,
black, lowered on nervasports, tinted windows
Postby darny64 » Thu Mar 28, 2013 9:43 pm
all the fascia says there for 07 models on but there all the same, will fit your 03 model
nik_rowlands3
Postby nik_rowlands3 » Sat Mar 30, 2013 12:21 am
https://www.ebay.co.uk/itm/RENAULT-Megan ... 518d12f4c6
I have that one in my megane 2 on a 55 plate
and its say 07 on so it will fit
Djorn
Currently Drives:: Megane CC 2004 Plate
Postby Djorn » Sat May 24, 2014 9:24 am
Hi Guys,
I have just swapped my Double Din head unit from my Honda CR-v to the Meggy...cut away the wee bar pluged the large Black and Large white connectors into an ISO connector, this has left a wee yellow and blue connector, which I assume is for the old 6 CD changer and stork controls...problem is I have no power...with ignition on or off...any ideas....failing that it might be a trip to halfords !!
This unit works fine out of the box in the Honda.
Any help gratefully welcomed.
Dj
Derekkirwin
Re: Single Din in 2003 Megane?
Postby Derekkirwin » Sun Oct 09, 2016 9:58 am
Hi, got a 2004 Megane I'm looking to fit a Sony dsx-a42ui aftermarket unit I've bought the right adaptors for it but they are sending me the single din for the tuner list head unit what facsia will I need to fit my new head unit,
As I'm stuck here help me with this as I've no music in the car and it's a long boring drive to and from work
Thanks in advance
Derek
