Oil in Engine Bay - See Picture
safc2005
Postby safc2005 » Sat Jun 23, 2012 10:34 am
Hi All,
Just wondering if you could assist on the below picture items C and E (link from post on herw - thanks "davelowe")
I have oil in the engine bay it appears to be either coming from C underneath and standing oil on E?
If you could assist that would be great, I would like to know what 'c' and 'e' are aswell please?
Steve
Megane dci 1.9 on a 53 plate
Re: Oil in Engine Bay - See Picture
Postby davelowe » Sat Jun 23, 2012 10:15 pm
Photobucket seems to have cropped my image. It's late now, so, if no one else intervenes, I'll check it out tomorrow.
Shanus1988
Currently Drives:: 05 grand scenic
Postby Shanus1988 » Sun Jun 24, 2012 9:08 am
Check inside pipe B for oil, if there's any at all it's from your turbo but make sure it's not coming from your oil cap.
Postby davelowe » Sun Jun 24, 2012 10:42 pm
The oil cap bottle/dipstick can get blocked.
safc2005
Postby safc2005 » Mon Jun 25, 2012 7:09 pm
Thanks for the response guys, last time I looked it didn't appear to be coming from the filler cap, only the wet oil under 'c' on davelowe pic, would it be easier if I took a picture?
I am having to top the car up on a weekly basis as the oil-level / service light is coming on.
Thanks in advance.
Postby davelowe » Mon Jun 25, 2012 10:23 pm
Take a picture, it is always useful.
What I alluded to in my previous reply was that the PCV hose goes into the filler bottle. It should separate oil mist from other vapours, the former is designed to drain back into the sump surplus oil. When the small tube at its base gets blocked with wax, oil is sprayed into the intercooler and other places it ought not to be. My solution was to unbolt said bottle, and clean it and associated pipework. This can cause all sorts of ms-diagnoses including a failing turbo.
Keyholder
Currently Drives:: Mgf 1.8 (1996) ( currently in the garage )
1.9dci Renault Megane 3rd Dynamic (2003 ) - De-cat, Remap - Larger intercooler - Head ported and polished - Custom made pipe work. ( currently on teh front garden in bits )
1.6 Maxim Renault megane (56 plate ) ( ready for the scrap pile )
Currently driving Mondeo 2.0 TDCI
Postby Keyholder » Wed Jun 27, 2012 12:43 am
safc2005 wrote:Hi All,
Steve
C is a diaphram valve which controls a butterfly valve ( by vacum) inside D - As far as im aware E is just an air defuser , aka airflow disrupter., as there are no mechanical or moving parts inside E just a few slots, which air can travel into disturbing the path of air traveling to the intercooler.
I myself has oil coming out of C, which is probably due to a, past turbo failure and not being cleaned up correctly, b, have blocked oil passages on the system, mainly oil bottle / catch tank.
Postby davelowe » Wed Jun 27, 2012 10:35 pm
Check the 'tank' / refill bottle. It only needs three 10mm head bolts to pull off - I bet you £5 its blocked with crap - that or the other lines...
Keyholder
Postby Keyholder » Thu Jun 28, 2012 9:42 am
davelowe wrote:Check the 'tank' / refill bottle. It only needs three 10mm head bolts to pull off - I bet you £5 its blocked with crap - that or the other lines...
2 x 10mm bolts , :grin , and yes im betting its blocked with crap to. .. . . . wouldnt think it would be blocked as bad as they turn out to be.
Postby davelowe » Thu Jun 28, 2012 10:17 pm
You owe me £3.33 :grin
Let us know how you get on.
Keyholder
Postby Keyholder » Thu Jun 28, 2012 10:55 pm
davelowe wrote:You owe me £3.33 :grin
lmao i owe you :conf :conf :conf :hm
I think you been sniffing them diesel fumes to much and they sent you all ya know :nut :nut :nut :lol:
:pc
Postby davelowe » Fri Jun 29, 2012 10:21 pm
LOL - I suppose the question remains - did cleaning the bottle and tubing fix it?!
Users browsing this forum: No registered users and 79 guests
