Locking nut lost and need to change tyre.
danielbanks
Postby danielbanks » Fri Jun 15, 2012 1:05 pm
Hi all,
Changed a puncture last week and put on spare. Decided to take car for a spin to make sure ok. Only problem is, I left the alloy locking key on the tyre and I have now lost it!!!
I currently still have the full spare on and the orig tyre has now been fixed (slow puncture). I have looked on eBay but unsure were the best place to get a new one from.
56 plate 1.5dci dynamanique.
Dan B
Re: Locking nut lost and need to change tyre.
Postby AlexB » Fri Jun 15, 2012 1:26 pm
Secret bolts are pointless. Just use regular bolts after removing the secret ones. They are usually removed by hammering a socket on them, which takes 5 minutes. Any garage can do it.
It might be possible to order a replacement socket, if you know the manufacturer and the code of the secret configuration.
tomalamix
Postby tomalamix » Fri Jun 15, 2012 3:54 pm
usually that kind of secret sockets have two keys, one to be used when necessary, and another one to be spare. even more, if you have the box of tat secret sockets you will see a no. written, with that no. you can order a spare socket. after all brute force will solve the problem also..
good luck
denzilpc
Currently Drives:: megane convertible
Postby denzilpc » Fri Jun 15, 2012 4:14 pm
Had no locking socket when i got my megane went to local deal who took a photo of nut then was able to order a new one got it next day
tomalamix
Postby tomalamix » Fri Jun 15, 2012 10:03 pm
denzilpc wrote:Had no locking socket when i got my megane went to local deal who took a photo of nut then was able to order a new one got it next day
how safe is that kind of "security" nut really? with a photo is "cracked"...
dcikev
Currently Drives:: 1.6vvt coupe, 1.9dci scenic
Postby dcikev » Sat Jun 16, 2012 8:45 am
i bought a lock nut removal socket from Halfrauds for about £17. Once you have removed the nut it is then useless and you would have to replace the full set of locking nuts!
Postby AlexB » Sat Jun 16, 2012 10:33 am
A professional universal secret bolt removal kit costs less, only £10... Search ebay! The fact that something is cheap at Halfords doesn't mean that it should be attached to one's car.
Why do you call the secret bolts a lock nut? A lock nut is a completely different kind of fastener, which is not a bolt first of all, and then it is designed to not loosen under vibration.
dcikev wrote:i bought a lock nut removal socket from Halfrauds for about £17. Once you have removed the nut it is then useless and you would have to replace the full set of locking nuts!
danielbanks
Postby danielbanks » Mon Jun 18, 2012 6:00 pm
More help needed.
Spoke to 2 dealerships and one said the part has to come from Gaurd direct.
The other said I can order it and it can take 3 weeks!!!
Another garage said £30 and he will take the locking nuts off all tyres and just put normal bolts on.
Does anyone have a spare I can buy. Willing to pay good money?
What's everyone's best advice.
Thanks chaps.
Dan B
dcikev
Postby dcikev » Mon Jun 18, 2012 8:19 pm
For £30 i would take the car to the garage and get the job done! hassle free..
Postby davelowe » Mon Jun 18, 2012 9:47 pm
Postby joeishmather » Tue Jun 19, 2012 5:19 am
I have one, but I guess the 'key' may not be the same shape, I can add a photo?
ikhan
Postby ikhan » Tue Jun 19, 2012 2:58 pm
davelowe wrote:https://www.youtube.com/watch?v=mJUUyjJqk5A&feature=plcp
I tried this on my mate's Avenis a couple of years ago - but I didn't realise that the collor on those bolts spun around so it was useless. He ended up having it done by a tyre place.
Renault Megane 1.5dCi (106)
Lowered 45mm (Spax)
Users browsing this forum: No registered users and 96 guests
